WYZE keypad should not be able to lock the WYZE Lock if the door is opened
When I press the lock button on the WYZE keypad it engaged the WYZE lock mechanism into a locked position even with the door in the opened position. I don’t think you should be able to press the lock button on the WYZE keypad and have the WYZE lock lock the door (engage the locking mechanism) when the door is opened. It should probably blink and beep warning you to close the door first. This is the same as the WYZE Lock not auto locking when the door is in the opened position.
Also, The WYZE app allows you to click on the lock button for the WYZE lock and lock the door even if the door is in the opened position. I don’t think this should be allowed as well. It should probably just give you a warning that the door is in the opened position.
I like your post. You need to vote for it yourself ! For your vote to count, you must click the VOTE button at the top of the page.:thinking:
