What specific features are you looking for?
It will do basic functions of an alarm system. system.
Here’s some features:
Wyze Home Monitoring Features
24/7 professional monitoring
24/7 emergency dispatch available
New security-focused hardware
Battery backup in hub
Works with Wyze Cams( Wyze Cam v2/v3, Wyze Cam Pan, Wyze Cam Outdoor)
Integrated video events
Ever-growing cloud-based AI assisted alerts
In-app arming panel
Sensor status dashboard
Monitoring events summary
Critical Alerts (iOS only)
Home and Away monitoring modes
Test Mode
Monitoring certificate for home insurance discounts
Single-tap export of video events
Hub
Wyze Sense Hub connects all sensors to the Wyze app and has a built-in siren to ward off would-be intruders. Placed in a central location of the home, Wyze Sense Hub can connect to the internet via WiFi or ethernet and has battery backup should it lose power.
Keypad
Arm and disarm the system directly from the Wyze Sense Keypad. With an adhesive back, Wyze Sense Keypad is mounted on a wall near the door, making it easy to arm and disarm the system without having to open the Wyze app. The LED back lit keys will light up when someone walks near the Keypad, making it easy to find at night.
Entry Sensor
Place the Wyze Sense Entry sensor on doors and any ground-floor windows to be notified if one is opened or left open.
Motion Sensor
Place the Motion Sensor around your home to be notified when motion is detected within the 25 ft and 120° FOV detection zone. With adjustable sensitivity settings and alternative “Large pet installation” instructions, Wyze Motion Sensor is designed to detect people, not pets. The adhesive back makes it easy to install on walls with the option to use screws for added security.
If there’s any features or ideas you have that currently not available, add them to the #wishlist if they’re not there already!
