Wyze Home monitoring nonstop notifications
How in the world do I turn off the notifications of the motion and door sensors when I’m home?
I’m getting thousands of them to the point where I’m going to turn it off. My system is not armed.
The v2 sensors are standalone hardware. The HMS is the service that uses the events from the v2 sensors to trigger alarms based in the events from the sensors. Currently the easiest way is to create a shortcut to use to disable the sensor notifications, then I’d you want another shortcut to turn them on again. But the HMS takes the events, which still occur to trigger. Notifications are not triggers. There is a wishlist which requests the feature to control notifications settings based on your alarm mode in HMS. Check it out and give it a vote!
Will do.
Wyze really needs to step up its Alpha testing. This is basic stuff, really.
