Got the headphones today. Love them. Excellent. Best $50 I’ve spent in awhile.
Question on the firmware updating… the app says that the headphones have an update to ver. 2.1.182 but they are currently at 2.1.105. And the app says “Individual Upgrade only”. What exactly does that mean?
The individual upgrade only means you cannot do it from the bulk upgrade screen, you must go into the headphone settings then device info then firmware.
I’m having the same issue. The update is showing through the bulk account firmware update, but when I click on it updates nothing and just goes to the main headphone page. No firmware option through the headphone setting.
I have the same thing showing up for me. I have an android phone not sure if its just the android app. If you connect to the headphones then go into the settings and then select device info you will see that its already on the latest firmware version (2.1.105). However in the bulk fw update window it shows its on 2.1.82 and needs to be updated to 2.1.105.
