Wyze Hand Held Vacuums Dead--yes, plural
I have two Wyze handheld vacuums. They both died at nearly the same time. It’s been a couple months at this point, and I’m thinking about junking them.
One was always plugged into a surge suppressor, and the other only rarely. Neither will take a charge, but the power supplies seem tip-top (32V). Voltage is fine even when plugged into the wall and a battery my meter show no current being draw–in either case–not like they’re browning-out under-load. Displays never come on, simply dead.
Dust cups, filters clean.
Any advice?
-Jeffrey
The Same happened to mine around the same year I was extremely upset because I took care of it and just out of the blue it just didn’t turn on or took charge. Still very upset.
Did you get any help on this.
I had not been using my Wyze handheld vacuum hardly at all. I went to use it and it died after 2-3 minutes. I left it on charger and still no luck??
Uh oh.
I just tried my handheld vacuum again. It shows as fully charged.
On high speed it lasts about 5 seconds and then shuts off.
I can turn it on again and same thing happens…
:star2: BINGO
:star2:The old behind the metal screen trick!!! :point_left::point_left::point_left::point_left::point_left:
Handheld Vacuum is now working again!!! :grinning:
Thank you @escalante
Impressive find.
No, they don’t take any accountability unless you bough it less that a few months. I saw some solutions that explained how to open and check if anything is broken inside and I saw one loose cable that might be easy to weld.
