I had been using a Meross GDC before Wyze even came out with one, but it was destroyed in a fire. I contacted Meross and got their accessory RGR551C for yellow learn button openers. What it is is a remote with external leads. You program one button to your opener and if you short the two external wires, it opens and closes your garage door. I am using this with a Wyze GDC. It works perfectly.
This is exactly what I was thinking would work! I have a working meross and accessory. Do you think it’s worth buying the wyze controller to use with the accessory, to be using one ecosystem? How do you like wyze vs meross?
And wyze engineers, why can’t you buy a similar accessory to make the gdc compatible with all models? I doubt you’d have to produce it yourself.
I have Wyze everything! So I chose to go that route. If you have the accessory it will work with the Wyze controller.
I can now confirm. I bought the Wyze Garage Door Controller, clipped the wires into the RGR551C accessory from Meross, and it works flawlessly. RGR551C programs in 5 sec. Wyze v3 camera was a bit finicky about being close enough to the QR code; but since it’s just USB power wire, and everything else was wireless, I could put the camera anywhere I wanted in the garage (that was close enough for the camera to read to code).
So, if you like Wyze, but have a garage door opener with a yellow button, see if you can get your hands on one of these accessories, and it’ll work in a snap.
Nice work. Nice of you to test this out at your risk/expense. Many will benefit from your experiment. And the collective thanks you.
Anything CURRENTLY sold at local Big Box Stores Supported ?
Chamberlain
Model B4603TCMRC
Model B2405CLD
Model B4613TC
Model B4505TC
Model B6713TC
Model B6753TC
Model D2101C
Skylink
Model ATR-1612BK
Model ATR-1722CK
Model ATR-1723CK
These are models that you can go out a buy today, there all current models, Does the Wyze Controller work with ANY of these, because NONE of these are listed on the compatibility listing.
Here’s the main thing as I understand it, Wyze’s GDC (Garage Door Controller) doesn’t natively install to work with Garage Doors that use the Security+ 2.0 protocol.
So if it has a round yellow learning button, then it is technically not compatible. The Security+ protocol is a proprietary standard for I believe Liftmaster/Chamberlain, making it harder to support (probably because they want everyone to either use “MyQ” system, or pay them more money to support their proprietary protocol).
Having said that, I have an “incompatible” garage door opener using the Security+ 2.0 protocol and a round yellow learning button, BUT I just wired the Wyze GDC to a Garage door remote control instead of directly to the Opener, and POOF! It works for an “incompatible” Garage door too. I followed the steps in this thread:
Using that method, basically every Garage Door Opener is compatible If you’re willing to use a remote instead.
THANK YOU FOR YOUR INPUT. I have NOT bought the Garage Door Opener but I have DOZENS of Wyze devices (including a Garage Door Controller) I would like to use, I am NOT picky on what I buy for the Garage Door Opener, But it seems like to get an older more traditional GD Opener is the Best Idea, That’s why I added the SkyLink’s (but Wyze doesn’t get into Models except to misspell ATOMS) I was looking at the Model # ATR-1722CK but couldn’t find any Wyze support for it.
Yeah, I totally understand that! I would be doing the same thing as you.
Like I said, I can’t really answer all the questions about everything that is or isn’t compatible, BUT I knew I could give you a little bit of reassurance that if you end up choosing one that isn’t compatible, there is still a way to make it work okay anyway, just like I did with mine.
The remote option is an awesome workaround and the remote battery honestly seems to last forever anyway. I’ve been pretty impressed so far.
I have a huge amount of wyze products. They are a fantastic company. But im extremely disappointed that i can’t use the garage controller (yellow learn button) without doing a bunch of crazy soldering and an extra remote. You would think that with the number of people asking, wyze would make these compatible. Wishful thinking i guess ![]()
I have two Liftmasters doors with a red button and one Chamberlin garage door opener with a =n orangish/yellow button. One Liftmasters is a regular ceiling mount and the other Liftmasters is a wall mount. The wall mount is need because I have a car lift in my garage, so I need the ceiling clearance. The Chamberlin is a ceiling mount too. I currently have a MyQ controller and I would love to replace the MyQ controller with a Wyze controller since I have many Wyze devices, and I have a yearly subscription. When will you have a Garage door controller that will work with any garage door just like the garage controller buttons in my vehicle and the exterior mount keypad controller that exists in the market? It seems like a simpler solution to use a Wyze keypad controller that can control several garage doors and a hub or sensor to trigger a camera? The entry exit sensor can detect open or close and I can create a rule to control any device I have including cameras facing the door. Please think about a new architecture and design at a cheaper cost. I can get one universal keypad controller for $20.00 if I can just get it to connect to the Wyze hut and control it from there. I’d be in for $20.00 and add the cameras and entry and motion sensors I want. Let us create our own bundle and give a bundle discount. I’d only need one keypad controller, one motion sensor, three entry sensors, and an OG wide angle camera to watch and control my garage.
Thanks
FYI, Wyze staff does not browse through this user forum looking for issues or questions. To get their attention, buy probably not a direct answer, you should turn this post into a posting on the Wish List.
Thanks
This wishlist topic is the appropriate place for Wyze visibility.
Can you support TopLift
I have a Chamberlain D2101, how complicated it would be to make it compatible?
Reading other forums users have posted about using an extra remote and soldering two wires to the inside of the remote. You then hook up these two wires to the Wyze GDO. I can certainly solder and do this but I was looking for an easier solution. In another post a user mentioned an accessory offered by Meross. It’s an “RGR551C”. It’s just a compatible remote that can be programmed to work with a Chamberlain GDO. It has two wires already attach inside and comes out to a handy connector to easily connect to the Wyze GDO. The “RGR551C” from Meross costs $14. I recently ordered one, linked it to my Chamberlain GDO, hooked it up to my previously installed Wyze GDO and it works great. (I just placed the “RGR551C” on the bracket just above the Chamberlain GDO.) Now I can get Alexa to open and close the garage door! Just do a search for “Meross RGR551C“.
Or here is the link: RGR551C-Accessory – Meross Official Store
You would of course need one for each garage door as well as a Wyze GDO kit as well. If you want to be able to control more than one garage door opener.
Exactly! No soldering required. This is the solution I mentioned in my earlier post. Wyze Garage Door Controller - Compatibility with More Door Openers - #24 by Latriea
The RGR551C-Accessory – Meross Official Store works like a charm connected to the Wyze Garage Door Controller.
