Using garage door controller on incompatible system
I have a Chamberlain Security+ opener (LW5000EV) that is not compatible with the Wyze garage door controller. However, after some research I found this product and have gotten it to all work together:
If you’re in the same boat I was and want to use the Wyze ecosystem, this adapter works great for me!
Twinfeats…you simply installed this AND the Wyze garage door controller and the Wyze controller worked? I have the same opener and want the Wyze controller …thanks for your help
Right - the adapter just goes in my wall door unit and connects to the Wyze controller box how you’d connect the Wyze box to your garage door opener.
Thanks!!! Got the adapter and the Wyze garage door controller all installed and working today!! WooHoo!!
Good to hear!
