Wyze Floodlight cycling on and off
I have a Wyze Floodlight/Cam V3 combo installed on my front porch. The camera stopped working (wouldnt connect to network), so I swapped out the camera only. New camera had same issue. I stopped using the direct plug to the floodlight base,and switched to using the USB connection port. Camera now works perfectly, but after dark, the floodlights cycle on and off constantly. Being connected to the USB port instead of the direct connection, i do not have the ability to control the lights from the app. Currently, I am turning off power to the entire unit at night because the constant cycling of the floodlights is annoying. Anyone experiencing this, or have a fix???
