Looking for help. Floodlight is working but the camera is not. Showing offline. Error code 90 . I have reset router and modem and turned breaker off to that circuit. Wondering if there is anything I can do, other than get my ladder and take it off power.
Yeah I usually just remove the power to the V3 and that fixes it. Not sure beyond that what to try. If you turned off the breaker and then back on that usually has worked for me
