Floodlight 2nd cam USB
So for over a month I have been struggling with the dreaded v3 “error code 90” on my second attached camera from my floodlight. I have tried mulitple working V3’s, and v2s and they all come back with this. Support replaced a few cameras I had, but still the same message. Its only affecting the two additional cameras I have attached to my two floodlights. Its about 8 ft away from my wifi router (google wifi) and I dont know what is going to or what to do with this anything. Anyone else having issues with it? Hard reset works for 20 minutes, then the connected camera to floodlight goes offline again.
Do the same cameras work when plugged in with the power adapter included?
Yes they do
I have done that for both the second camera and floodlight, same results
I have the same problem. The V3 camera works for a few days, then goes off line. I have tried everything mentioned here. I got a wifi extender and even got a more powerful internet from Verizon complete with its own extender. Nothing has worked. It is becoming very annoying and frustrating.
same with me. I even put the router next to the camera outside and still have the issue. From what i can tell (and from others) its not getting enough power! Wyze needs to correct this or not advertise it
That’s interesting. I had not thought of that. So, it may be that it needs it’s own power and cannot be linked to the floodlight. The connecting cables may be at fault too?
i have tried 9 cables, all with the same results, its not getting enough power from the floodlight USB
I’m not having this issue, I would contact support and try to get a replacement. https://support.wyzecam.com/
What does Wyze support say about this?
I never hear back from support on it and I just gave up
Ever figure it out? I was having a similar issue and I realized that the QoS on my router needed to be turned off. Now everything works flawlessly.
