Floodlight cam stopped connecting. Now cannot Connect
My floodlight cam3 has worked great for two months. It now won’t connect. Signal is strong. Cannot disconnect power.
Welcome to the Forum @mrogers731!
Sorry to hear of your issue.
When you say the camera won’t connect… Are you saying you cannot pull up live video? Or is the camera showing as offline and you cannot interact with the settings?
@Rulwiz does offer some advice for “Rebooting” the whole device, if needed.
This week my V3 cam attached to the floodlight keeps going offline. I reset it every day for the last week and it continues to go offline. The floodlight works just fine. It’s just the cam. Any idea why? I don’t want to climb up a ladder to reset the camera to fix this issue.
Are you able to view the livestream when clicking the cam?
No I cannot. It’s completely not connecting. Says it’s not connected to the internet. All my other cams are connecting just fine. This has been happening since Sunday. I’ve honestly been having issues with this floodlight cam since I bought it. just not to this extent.
I do have it connected to a light switch. I do turn it off for about 30 seconds and then turn it back on. This method works 50/50 but then I have to do this almost every day for the last week.
The cam stays online and working for about 12 hours then goes offline again. What is really weird though is that I have a micro as card in the cake and I can view playback video of when the cam says it was offline.
I had this same issue. I dont believe there is enough power being supplied to the 2nd camera. MIne would work for a day or two, then constantly have to reset it. I got tired of having to always pull my ladder out to reset it and just disconnected it (and about to throw the floodlight out too with all the issues it has with connections). Its sad that this is the case- what a great product and idea to daisy chain a second camera, but what good is it if its not getting enough power to work consistantly?
I’m now having this issue! Very frustrating! Turn the power off to the device…turn it back on and it works for a few minutes or hours.
Did anyone find a real solution to the problem?!
I’m hanging the same issue.
I had to delete the device and then reinstall as if new. It then worked fine for about a week at which time it happened again. I deleted and reinstalled again and it’s been fine ever since :crossed_fingers:
Same thing. I have to keep flipping the switch for it to come back online. I have found two settings almost bricks the Wyze Cam V3 every time: the siren shortcut and the flash with siren option. Don’t touch those two options. This is clearly a firmware problem and not hardware. They have sleeping on beta bugged firmware for too long now. Wyze gave me a gift card for the value I paid for the floodlight but I had an electrician install it. I would need to pay an electrician again to remove that one and install a new one. Real bad Wyze. Fix the firmware.
Same types of issues. Eventually basically died, wouldn’t boot up. Support determined it out of waranty so no replacement. Tried to find the firmware to reload. Apparently unavailable. As a last ditch effort, I put in a RTSP card I had used on a V3 camera. It booted and I now have a good camera with an uncontrolable floodlight that turns off and on seemingly randomly all night. On mine the camera appears to be permanently attached so no separating the two. Better than the trash can, maybe… Not one of their best products.
Next time do what I did. Never buy from the Wyze App or Wyze Page again. Only buy them from Amazon or Home Depot, etc… I prefer to go somewhere to get a refund (without hassle) and buy it again (Amazon is quick on Delivery and Refunds) then to waste 5 days emailing support just to get a Gift Card (on the fifth wasted day) and a “I’m sorry you paid an electrician”. I’m pretty sure this Floodlight needs a massive recall because problems with this Floodlight is all over the web. I’m surprised nobody has sued or pushed for a federal recall. The last guy (three different people wasting my time) just looked at the serial number or MAC and said “here is your gift card”.
I’m having the same issue with both of my floodlight cams. Wyze please contact me to make this right. Solution is to give me two new cameras and I’ll have them replaced
Welcome to the Wyze forum @thebaileyranch.
This is primarily a user to user forum.Wyze will not contact you for support, but you can reach out to support at support.Wyze.com
Same. Very frustrating.
I was able to get mine working by reloading the firmware. It not clear on their firmware page but it uses the standard V3 firmware.
Mine stopped recording a couple of weeks ago. Floodlight works fine. Thought, OK i’ll just reinstall. Now it tells me my wifi is too weak and wont install. I have a wifi extender 8 feet from the floodlight.
Frustrating.
Mine has the same issue. Cycle power only made the V3 cam works for few minutes and then disconnect/reset by itself. But when I take out the V3 cam from the floodlight and plug into another power source and it works just fine so I assume it could be power issue with floodlight when haveing v3 cam plug in.
Stopped working after a month - going back to my credit card company to do a return after 30 days. This has turned me off from Waze completely and their support is ridiculous. Already ordered Ring replacements for the light and doorbell :face_with_symbols_over_mouth::face_with_symbols_over_mouth::face_with_symbols_over_mouth:
