Wyze firmware updates - Released 11/6/2023
WCO firmware update of 11/06/2023 for cams using Cam Plus
I updated my 4 Version One WCO cams and base yesterday 11/7/23. I am using cam plus on all four cams and had them set to “No Cooldown” period. I checked the settings today and they were all set at 1 Minute Cooldown.?
I recommend you check your setting on the WCO and see if anything has changed from your original settings. :raccoon:
[Mod Note]: Your topic and associated replies were merged for better visibility to Wyze and the potentially affected forum members.
Updated to which firmware version and using which app version?
Cooldown is whacked all over the place on my WCOv1 cams running 4.17.4.427 and WCOv2 cams running 4.48.4.427 using app version 2.47.0 (b372). Thank you for the heads up! :+1:
I use iOS firmware 4.17.4.427 and app 2.46.1 (4). I noticed that goofy green tagging box was on also, which I normally have turned off.
Seems to be a sometimes recurring issue when applying firmware updates. :face_with_diagonal_mouth:
I moved your topic and replies to this Wyze firmware update announcement topic for better visibility to Wyze and the potentially affected users.
Updated two Cam v2… observed a few days. Then updated remaining six.
Like this:
All good. :+1:
