Wyze Duo Cam Doorbell Firmware Beta Test 2/20/2025
Version: 1.0.24.23
Whar’s New:
  • Added support for automatically adjusting resolution when streaming in Wyze Web View
  • Fixed an issue where the status light displayed incorrectly after an unexpected reboot in AC mode
Updated without any issues.
Formatting function still doesn’t work. Everything else seems okay.
Can you show something showing it not working?
Seems to me it sees the card, reports the size and available, and the box says “Format completed”.
That’s the thing, it doesn’t format. And the used capacity does not zero out.
@nathaniel.hang go back a screen and hit restart for the cam from the app and check it again when it restarts, let me know if that works.
Already tried that. Restarted… go in and out of the menu. All the same, it doesn’t format/zero out.
That is rather peculiar let me try mine.
hmmmmm something tells me you are on iphone.
Try this just for giggles, go into app /account /app settings and clear the cache from there, and try it at that point. I’m not familiar with the fruits so I don’t know how to force stop on Apple but I wonder if for stopping won’t get it to stop reading from an old cache, something tells me it has cleared and it’s not reading that way. Normally the restart will get it to read correctly and it’s something I’ve been trying to work with the team on.
Mine is working correctly Android and I don’t know why the difference is happening between UI
Try any other cards?
Known working card from another cam?
Wake-up is still severely delayed.
I have two. One battery only and one hardwired.
Both wakeup after about 5 seconds of constant motion.
The following scenarios:
Cold weather entry or exit walking my dog and we make it inside within 5 seconds, no motion detection or recording
Wamer weather entry or exit walking my dog and she longers more than 5 seconds, motion is detected and there is a recording.
Everything else. Unless there is constant motion for 5 seconds, there is zero recording.
Detection settings are on high
