Wyze Duo Cam Doorbell & Cam OG Firmware Beta Test 1/15/2025
Wyze Duo Cam Doorbell:
Version: 1.0.24.21
What’s New:
  • Updated Edge AI
  • Added PIR trigger validation in AC-mode to reduce false recordings and alerts
  • Optimized wake-up logic
  • Improved motion filtering algorithm to avoid false detections caused by color changes and device sleep transitions
  • Fixed an issue causing partial video artifacts in cloud recordings
  • Optimized pre-sleep process
  • Added support for resolution switching during live streaming via the web interface
Wyze Cam OG:
Version: 1.0.90
What’s New:
  • Security improvements
Upgraded 7 OGs with no problems.
Updated the firmware for 1 DCD w/o any issues.
Formatting function of the SD card still appears broken.
Installed on my OG’s and the Duo Doorbell without issue. Seems to be functioning fine
I wonder if “Security improvements” for Cam OG means it doesn’t restart itself anymore automatically after 30 minute of internet outage. Cam V3 beta firmware 4.36.14.2259 had the exact same wording in its changelog and that was the only thing changed AFAIK.
Too bad I don’t have Cam OG so I can’t specifically test this.
Updated my OG went fast and seams to be working fine at the moment.
There are many people who hope that this will be solved. The memory says 0.0 GB and does not allow it to be formatted.
one of my OG cams updated fine to 1.0.90. The other does not. It says it updated but the next time I check firmware under Device Info it is still at 1.0.84 and prompts to update to 1.0.90 again. Restart on the cam did not help.
Edit: After looking closer I found neither of my two were updated.
I take it back, all 7 updated OGs are downgrading when I open them. All showed updated, as I open live view each is again asking to be updated again.:person_shrugging:
Same issue here as well
@WyzeAndy @WyzeJasonJ @WyzeDesmond
The Beta Firmware update for the OG Camera seems to not take. It goes through the process, quickly, and says it has been updated successfully. But then you go back and it is still showing the old Version.
I submitted log: 1728324 for the issue
This is what it shows when update has been completed
Then when you go back, it shows that an update is available as shown in this image
same inability and behaviour attempting to upgrade my sole OG from 1.0.84 to 1.0.90(beta). after about 10 sec says all done, but still has 1.0.84 and has not rebooted.
note i seem to recall a few months ago giving Wyze my cameras MAC address with which they ‘pushed’ f/w onto this OG.
Same on my 5 OGs. All seem to update fine but when you access each camera it reverts back to the old version.
I reported it, hopefully someone will respond.
Update. It appeared that it updated but when i checked again it had not. Did this several times still not updated. Now shows no updates available and its on 1.0.84.
