Wyze Cam OG & Duo Cam Doorbell Firmware Beta Test 3/12/2025
Wyze Cam OG Firmware:
Version: 1.0.92
What’s New:
  • Security improvements
Wyze Duo Cam Doorbell:
Version: 1.0.24.25
What’s New:
  • Improved event thumbnail clarity for free-tier users
  • Optimized PIR trigger algorithm to reduce false activations
  • Fixed inaccurate Wi-Fi signal strength display during setup
  • Enhanced motion filtering algorithm to minimize false alerts
Doing the updates now. Will report back if there are any issues
EDIT
Duo Doorbell updated without issue.
@WyzeJasonJ @WyzeAndy
OG Cam Received Update Failed from the Group Updates Page. Tried twice with same issue. Restarted the camera and then went to try again and it showed as being updated. So there is an issue which indicated that the update failed when it really did not.
I don’t have a Duo Cam Doorbell to test, but this is cool to read:
I hope some people who like to complain about a push toward subscriptions are paying attention to things like that. :crossed_fingers:
I also hope that improvement is highlighted when this is released to production.
@wyzejasonj @wyzeandy
RE: Wyze Cam OG Firmware: Version: 1.0.92 shows as “Update Failed” but actually updates.
I also had this issue - Android app (3.4.0.b365) and 5 OG cameras.
It was the same with the 1.0.91 update.
Interesting, I did not have the issue on .91 as you did. But your confirmation on what I experienced is grateful.
I am also on Android app (3.4.0.b365)
And I see that the OG-Tele is still unloved. No new update - still on 1.0.80. I don’t understand why the Tele does not get the OG updates when the only difference between the OG and the OG-Tele is the lens.
OG CAMERA::
App says update failed, although the camera itself says out loud update successful. On bulk update page still shows failed update however if you go to the camera itself and look at the About, it shows the correct updated firmware number and when clicked on it says it is up to date.
Android App Version: 3.4.0 (b635)
Firmware Version: 1.0.23.25
Plugin Version: 3.4.0.4
Last night I was experiencing issues with my Duo Doorbell and connectivity. Basically I changed the sensitivity to 10 from 6. here are 3 issues I am experiencing now:
  1. Doorbell does not seem to be notifying on person unless they are directly in front and near the doorbell. Prior to this release I would receive notification as some was in view of the doorbell, on my driveway.
  2. Sensitivity at 10 seemed to not allow the Doorbell to connect. Instead it would sit spinning on step 1. I would do a Force stop, Clear cache in the app and the in App info on Adroid. Restart the phone and then it would connect. after connecting one time, I would experience the same thing, Performing the same steps would allow me to connect. I decided to lower the sensitivity to 6 and this corrected my connectivity issue.
    Log for this issue is: 1787690
    Image of what I am seeing is:
  3. I tried to format my SD Card and it indicates it was completed but formatting actually failed.
    Log for this issue is: 1787701
    Images of what I am seeing is:
    Screen load   Format Screen  After format
    Notice SD Card remained all green and not formatted.
For the Wyze Duo Cam Doorbell, the false positive detection algorithm is still too low. I just tested: I had 8 full seconds of my car coming into detection range. and another 20 seconds of me waking to my door and unlocking. Only the 5 seconds of taking keys out and unlocking the door triggered motion detection and recording.
I’m AC powered. One recommendation is giving used the ability to turn off the minimize false alert algorithm if not on battery power.
Additional info, I have a video power Doorbell Pro mounted right above the Duo Cam, it picked up at 10 seconds of that 20 second walk. So at about 10 - 12 feet , it can detect me vs a few centimeters away than the Duo Cam
No comments from Wyze on OG update fails, but actually updates or says it did?
My update a few days ago wen well and have not had any issues. My doorbell mostly does person and package but accuracy has been normal with almost no false positives…although i wish package detection could know a package was already there to reduce repeat notifications.
It will keep notifying you until someone swipes it.
Oh I’m aware hahahaha. I feel it has improved (or my config has) the last month or two.
Edit: New firmware update 1.0.94 released today brought both cameras back to life. Good thing I didn’t chuck them.
It appears that two different OG cameras died at exactly the same time as the IR lights activated. The last viewable image on both cams is totally pink. They now appear to not function at all is if they don’t have power. Even pushing setup does nothing, and unplugging even changing power bricks, they make no sound, or lights, or anything. Error 20002
I couldn’t get our OG cameras to authenticate and load the live stream. My service provider did an update on their end and that fixed the problem on my app and I have live stream on all cameras. I share the cameras with two people and they cannot get the live streams to load on their end. Is it still an issue with the Internet provider or is there other suggestions? Thanks.
Maybe the sharing never set up right due to that issue. You could remove the sharing and re-share with them and see if that helps?
Does yours work both when on your home wifi and when away from home?
Yes mine works flawlessly wherever I am. I just unshared everything and reshared and they can see the base station cameras but not the OG’s
I believe he did an update to the service and he also put it so it has a password now as we were running without a Wi-Fi password before. And the code that pulls up on their phone when they’re trying to upload the camera is G99
Not sure what you mean. As long as the cam has connectivity (which it does) when you use it, the other person does not need your wifi password or anything.
Just make sure they’re running the latest version of the Wyze app.
So are they able to add the camera to their account and the live stream just won’t load, or can they not add it at all?
