Just after I replied to you, video doorbell starting acting up and not connecting even with IR Night Vision Mode On! Wonder if Android users have as much problem as iPhone users?
In the meantime while we wait for a fix, here is the workaround that I found and let Wyze know about:
When your LIVE feed gets to “Step3: Getting video data” and gets stuck, press the gear to go to ‘settings’, select ‘Advanced Settings’, select Night Vision ‘On’ and then ‘Off’, then press the ‘<’ key to go back to LIVE feed and it will connect.
It took me a long time to find this workaround. I expect that it will work for everyone having this issue since it seems to unstick it by going thru night vision mode. Sorry, but if you use Night Vision, you will have to turn it back on. But, at least it is a reliable way to temporarily conquer this bug.
Your welcome. I hope it works for you too.
Thanks for this workaround! This is the only one that has worked 100% of the time for me. Hope others have the same results while we wait for a fix!
Update on workaround: I have been using the following sequence and it has been working on iPhone running iOS 15.7 100% of the time:
‘Advanced Settings’, select Night Vision ‘On’ and then ‘Off’ and then ‘Auto’, then press the ‘<’ key to go back to LIVE feed and it will connect.
At night, Doorbell camera will go into Night Vision automatically.
The only work around is use your fire tv remote with voice. It’s not just wyze cams that dropped, Alexa won’t display amazons own cameras anymore either. Very annoying.
Yes that’s the issue. Mine is also not allowing me to see video. I have sent to many logs to list. Error 09. I’ve chatted,emailed, chatted again, emailed again, tried to call and gave up after an hour. I uninstalled/ reinstalled the app. I deleted the doorbell and re added. I powered off the doorbell. I reset the router. I chatted again. I emailed again. I waited on hold for an hour and a half. Then I cancelled my cam plus and ordered cameras from a different company. If I charged minimum wage it would have paid for 4 of these doorbells in wasted time. I’m done with wyze.
I found a post in the amazon forum for alexa not displaying cameras, Sorry cameras don’t work on this device. Say “Alexa who’s at the driveway” or “Alexa who’s at the front door.” It’s the “who’s at” phrase that works. I’ve tried who’s on or who’s in and it doesn’t work. I hate updates.
Tried the command on my Fire TV Stick and the commands work
. Tried on my phone and Alexa remained sorry
Glad it worked on the tv. I never tried it on my phone.
I think that was the first time I ever got my doorbell to stream on my Fire Stick!
My other cams will stream, but Alexa is SLOW at loading.
All of mine used to work untill an alexa update. Now I have the wyze updates causing every issue that’s in these forums. They just can’t leave well enough alone.
I updated immediately upon notification & am a happy camper so far. What a joy to have live feed connect without a hassle! Updated my neighbor’s doorbell yesterday and it’s working great also. So far, it looks as if we have a winner.
Now I can’t wait to get the Wyze Cam V3 Pro in and test it!
Yeah, I found out the hard way…don’t try to use 5G network…I didn’t know devices were compatible only with 2G. Am I the only one that didn’t see that coming?
I realize this is an old problem discussion, but I seem to have the same problem with the lastest firmware version 4.25.1.333.
I have some additonal information. When I have the problem, mine doesn’t always get to step 3. It can also hang on step 1. If I activate another camera, when I return to the doorbell live feed it connects instantly.
It does continue to log an record events. I don’t know if those are recorded in the cloud or in the device. I’ve reset the doorbell and the problem is still the same.
I’d say there is a problem in the connection protocol in the doorbell. As soon as that other camera completes a connection cycle, it seems to open the door for the doorbell camera to complete its connection protocol.
I’m sorry you are having issues. My doorbell was beyond frustrating. I’ve gotten rid of all of my wyze cams. Every update caused more issues then it would take months for wyze to fix. It would hang up signing on. It wouldn’t allow my 1 year old phone to view videos suddenly. It would lose connection or take minutes to connect. I tried everything. Reset the doorbell. Reset the router. Delete and readd the doorbell. According to wyze it was always my router or internet. Then they’d do a new update and it would work. Then they would do an update and it wouldn’t work.I know what your going through. I just gave up on wyze. They were good for a while. Sorry.
