Wyze Doorbell v2 compatibility with 220V Chime
Hello All,
I have a 220V Chime and I want to make it work with the Wyze Doorbell V2 .
I understand that Wyze Doorbell V2 works only with 24VAC. I have a transformer that should enable me to connect the Doorbell V2 to electricity.
My problem is the Chime that only works on 220V, is There a way to connect it somehow to Doorbell v2?(PS: Where I live the Chimes work on 220V only, no 24Volt available).
Thanks
Where are you located? A 220v chime in a residential setting seems odd. Do you have a multimeter to test the voltage or is this just a voltage listing on the chime? Is there a transformer or is the chime direct wired in your breaker panel? The 220v could be a max limit and not the true service voltage. Is everything else 110-125 standard voltage?
