I have the nicor P18888 chime in my house, how do I bypass the chime wires? I was told by the manufacturer this Wyze video doorbell is not compatible with my current doorbell. Any help?
Looks as if it only outputs 9 VAC, beneath the Wyze specs. You can just buy a regular 16VAC doorbell transformer for $15.
120VAC/60Hz in, 9VAC/500mA out
Installs quickly into a standard two-gang dual-voltage wall box.
Combines line voltage and low voltage in a single unit.
Daisy chain capability (up to four Prime Chimes).
Recessed mounting.
Paintable faceplate.
Two different chime sounds for front and back doors.
Two lighted rectangular doorbell buttons.
