Wyze cordless vac rubber ring
So how many of you have lost the rubber ring from your cordless vacuum when emptying the dustbin into the trashcan? There needs to be a better way to keep that ring in place! I went to get a replacement online and they are out of stock for the last several months. Does anyone know where I can get a replacement rubber ring for my upright cordless vac?
Welcome @tnherm8
I personally have not. However ETSY sells some 3D printed ones which appear to work well:
https://www.etsy.com/listing/1144164373/wyze-cordless-vacuum-gasket?ls=a&ga_order=most_relevant&ga_search_type=all&ga_view_type=gallery&ga_search_query=Wyze+Vacuum+seal&ref=sc_gallery-1-2&sts=1&plkey=2678144fe4baceb012598fde3b8da836ce260d93%3A1144164373
or
https://www.etsy.com/listing/1477505083/wyze-cordless-vacuum-gasket-3d-printed?ls=s&ga_order=most_relevant&ga_search_type=all&ga_view_type=gallery&ga_search_query=Wyze+Vacuum+seal&ref=sr_gallery-1-9&sts=1&content_source=884e3061c0558ef7620f344db02be096ac4d8232%253A1477505083&organic_search_click=1&logging_key=884e3061c0558ef7620f344db02be096ac4d8232%3A1477505083
I use adhesive spray like used for automotive headliners. It doesn’t set up dry. The residue wipes off easily.
We have a water pitcher that has a little rubber band type gasket on the lid that kept coming off. I removed the gasket, sprayed it and stuck it back on the lid. Has been fine for months.
The can I have is old, but has been used for many glueing things.
People have been talking about this for years now and Wyze still hasn’t fixed the issue. It got so bad that for a while Wyze was replacing them for free, they did for me when I lost mine in the trash. Not sure how Wyze didn’t catch this issue during their testing.
Just lost mine. I order replacement on Amazon but they are very stiff Worried may damage the bin. I’ll look at Etsy. Thanks
Yep, Etsy has these:
https://www.etsy.com/listing/1144164373/wyze-cordless-vacuum-gasket?ref=hp_rv-2&sts=1&logging_key=6a783a7fc073d91b175839417689e5fdb3fa5a3f%3A1144164373
or
https://www.etsy.com/listing/1477505083/wyze-cordless-vacuum-gasket-3d-printed?ref=hp_rv-1&sts=1&logging_key=a015e6163fd229140f84509045b2beb57eade94b%3A1477505083
