I have a v3 that I’m able to connect inside to my Orbi mesh wifi. When I move to the garage, I have 100mbs download and full bars on my phone. The camera will not reconnect. After uninstalling it through the app in the garage, and attempting to setup, it still will not connect. I have an extremely strong wifi signal, I counted, it’s 10 steps from the ac3000 router that I set it up next to. What other things can I try with the camera? I also have smart plugs further away from the router that work fine.
So I went through the router and had to disable AX on the 2.4ghz band. This is a bummer as it hurts the performance of the network and would definitely help with video streams from the cam. Will we ever get AX support from the v3?
