Okay So, I got a new lamp for my office, not really a brand new lamp its one I used at a work for years just didn’t need it there any longer. Brought It home and took my two Color bulbs that I was using elsewhere that worked, and screwed them in. First bulb no issues, the second one will not switch on… Ive tried it in several different sockets… no issues turns on every time. put it in the new lamp nothing… took the first one I moved over into that suspect socket and it turned on… This second bulb will not work in this socket but like it said the first one will. Am I missing something, has this happened to anyone else, and is there a fix?
thanks for the time!
