Wyze can pan v3 issues
Anyone have issues with this camera picking up motion, losing connection OFTEN and not recoding anything, or it won’t turn all the way? Tired of this camera not working the way it should. Can I return it. I’ve had it for a while now.
If it’s over a year old it’s out of warranty
And even under warranty it won’t be easy to return for a refund.
Best you’ll get is help trying to resolve your issues **(if that)
That sounds like a power issue. Are you using the stock USB cable and power adapter?
How far is it from the router?
