Wyze cams wifi connection
I just now noticed my cameras need wifi when I’m checking on them out of the home, and they worked just fine yesterday 3/18/2026. Now I’m at work and wanted to check on my dog and now each camera says no connection becasue of off wifi but says no connection. I thought it just uses the home wifi and no need to be on wifi when out of the home. What changed? Everyone complained about wyze but I gnored t since mine were great, but now I’m re thinking Wyze. UGH!
I turned off the wifi on my iPhone 16E and did a test. It connected to all of my 15 cameras via cell data. Who is you cell provider?
Check to see if you can see your cams when halfway between home and work. Maybe your employer has started blocking your access to cam streams.
