Wyze Cam v4 Firmware Beta Test 9/26/2024
Version: 4.52.9.1134
What’s new:
  • Optimized video to fix reddish tint issue
  • Fixed a bug that caused a delay when turning off the siren
  • Fixed a bug that caused an issue where the lamp socket could not be triggered after turning off sound events
  • Updated spotlight UI and removed sound trigger
Updated 4 cams for initial testing. Looks good so far.
Updating all of mine. Will report if issues are found.
EDIT
Updated 6 V4’s without issue. Testing has yielded no issues, so far. :slight_smile:
I have two. One updated fine, the other is BARELY in WiFi range and failed (no surprise). I will try the one in the truck again when I have good WiFi for it.
What exactly was the reddish tint issue?
Wyze gave me a new V4 for such an issue a couple months ago and let me keep the old one with tint/IR issues that seemed at the time a stuck IR light…Only partial pink tint at night.
Anyhow updated all of my V4s and the old one and will see someday if it was tint or stuck IR.:person_shrugging:
Interestingly, also had 2 OGs that needed updates to 1.0.84. The V4 swap and the two OGs are sitting on the floor in the living, while I figure out a home for them. She doesn’t mind. Lol
One of the OGs is :coffin::wilted_flower::skull::joy:. I’ll jump on chat and setup a swapout.:person_shrugging: Tested with known operational brick and cable from the V4 in a known functioning outlet. Still dead.
Got my V4’s out of the box today!
The stock firmware was not working like i’ve expected.
Very poor Wi-Fi signal and continue disconnections.
With this BETA Firmware it works like it should!
I don’t understand why it’s so difficult to achieve a normal color rendition with this camera, it looked before like vibrance was jacked up. Now very washed out and overexposed. Would be great to get some user adjustments, at least for + and - exposure offsets.
Can you post a few pics so we can see what you are seeing?
Sure, here’s before and after on one of my Cam4
Another comparison
