I was wanting to upgrade a few of my Wyze Cam v2 with the v3. Does anyone know it the same power cord will work for the v3?
Thanks
Welcome to the Wyze community @mcgowan_john!
Yes, the power cord and brick should work properly with the V3 camera. The V3 also includes a power cord and adapter too.
Yes. Usb cord and micro usb connection are the same.
Yes, as long as it’s the stock V2 USB cable.
I had one V2 that needed a longer USB cable. When I replaced it with a V3, it refused to connect. I had to get a better cable. Seems the V3 uses more power.
I replaced a V2 camera with a V3 and used the stock V2 cable. While I was able to complete set-up, I experienced repeated disconnections of the V3 cam. Problem solved after I used the stock V3 cable instead.
