I’d like to update two of my v2 cameras, however, I currently have my v2 cameras mounted externally using a third party housing kit, where I ran the cabling through my soffit and into my attic.
I’m looking to avoid re-running new cabling through my attic. It would be much easier if I was able to simply disconnect my v2 cameras, and replace them with v3 cameras by using the same USB power cable.
It looks as if the v3 has a more circular connection. I know the v3 is rated as exterior use, but I may buy a new housing for it as well. So, I don’t care so much if the v2 cable is a perfect fit for the more circular connection, I just need to know if it is the same plug type which I believe is a micro USB, correct?
