Wyze Cam v3 Spotlight always on
My spotlight came on and never off after the latest update 4.36.11.7095.
No matter what I did, recycled power, disconnected, and reconnected still stayed on.
I am sorry this is happening. The newest version of the firmware is 4.36.11.8391. I would try updating to this version and see if the issue is still there. To update to this version you will need to be on app version 2.48 or higher.
Everything is good! Your camera is up-to-date.
4.36.11.7095
App = 2.48.9 (4)
Let me check and see if this firmware is still under gradual rollout. I will let you know soon.
Thanks
I’m having the same issue. I had my spotlight disconnected for a few months in my garage and now it’s always on. The app isn’t able to control it anymore (I see the manual control in the corner and pressing it several times doesn’t turn it off, and the settings doesn’t change if it is bright or dim . Tried restarting, delete / readd camera, new cable, new power brick, latest firmware for light and camera v3. I couldn’t view the firmware after deleting/adding it back but updating the wyze iOS app fixed that.
Thank you I try to update app update and report back.
Deleted and reinstalled the app did not work; the spotlight stayed on and can’t connect to Wi-Fi ~ Uh oh … Something is wrong. Please check your Wi-Fi connection message…
Same here.
same here
Same here last night.
On all night. From reviewing continuous recording, We closed a blind at 11:47 pm that triggered motion detection (from light inside house) on back of our white car. Didn’t trigger a recording, just detected, then it tried to adjust to darkness, probably still picked up some motion, triggered the spotlight (window blind already closed) and spotlight never shut off again.
Spotlight showed as “not installed” on app. Restarting camera and resetting services did nothing.
Unplugged power for 5 minutes this morning and plugged back in. Seems to be reset and spotlight shows “installed” now and is off.
Weird and annoying
Wyze Cam 3
Firmware 4.36.14.3497
Spotlight 0.0.0.16
App v3.6.6 (683)
