Thanks
Edited:yay it’s working so far on nest!!!
But not on Google HOME
Will test with my Google hom
Edit
I was able to stream my cameras in Google home, including the doorbell pro.
Can you provide what you are seeing, a screen shot maybe, a log, and the camera model you are trying to stream.
Thanks
Holding off on all of these until the WPA3 issue is resolved.
Any status updates?
Anyone, anyone? @WyzeJasonJ
I do not have any updates on this yet, they are still working on it.
No events of any kind are being captured on many of my V3 Pro cams. Many restarts and it is not fixing it.
Log ID: 1043178
Firmware: 4.58.11.4293
Interesting. I am running the same Beta on a Cam Plus Unlimited V3Pro Cam set to record all events and tag Person and Pet and I am getting appropriate Events and tags. I am also on the Android Beta App.
On mine, the spotlight refuses to activate on motion… ever. It will activate manually or thru an AI detection rule, but never on motion.
But (off topic for this thread) my OG cams have done an Event upload face plant.
I am getting Notifications from both V3Pro and OG and the Events are captured in the Events tab and on SD Cards. I am primarily using the Android Device but also have my iPhone and it is working as well.
Wonder what the difference is. Did it start Happening today?
No. V3Pro spotlight has been for months. OG started this weekend after the Beta App update. But, these OG cams are on stagnant FW. ![]()
I am going to have to check my spotlight again. Maybe I am set for AI on the spotlight. ![]()
Checking to see
Yea, just noticed that also. Testing in a bit
EDIT
Just tested and going through the events. My spotlight does turn on with Motion.
Where is the download link? been searching for it forever and couldn’t find it!
Welcome @nightOwl7 . I am a community Volunteer supporting the forum.
To get the Beta Firmware, you will need to make sure it is selected. here are some steps to register for Beta Firmware:
- Start the App
- Tap on Account Menu Choic
- Tap on About
- Tap on Beta Program
- Register or follow the steps. If Edit is in the top right corner, tap on it.
- Then select which devices you would like Beta Firmware for by ensure there is a check mark nect to the device.
- When done select Save.
If you need to register for the Beta App go here and follow the steps:
Become a Beta Tester – Wyze
