For outdoor use do you have to keep the V3 plugged in or does it have a battery that is being charged?
Hi @kadehumpherys The V3 cam is strictly USB powered, no internal batttery.
So how would having it plugged in outside void the warranty if it’s an indoor/outdoor camera?
There is a short USB cord out the back of cam with a sleve to keep water out. It is listed as:
Weather Resistance: IP65 Weather resistant, Indoor/Outdoor so no problem with warranty.
Wyze Cam v3 Tech Specs
edit: As of March 08, 2021 21:47 Content is in-Progress.
(https://wyzelabs.zendesk.com/hc/en-us/articles/360051120391-Indoor-Outdoor-Use)
No battery…
Hi I am also a newbie I have ordered my Wyze cam 3 and as I will connect to power source inside the garage, so water ingress would not be a problem. I will drill a hole for the usb pigtail to go in. However I do need a longer extension insdie the garage to a power socket, I was thinking of using this:
https://www.amazon.co.uk/gp/product/B077ZL3F62/ref=ox_sc_act_title_1?smid=A2JGDQIZ6HYZ2E&psc=1
As long as I can plug it into the pigtail ? That is one of my questions also as I am in the UK would I have to us a 5 volt power adapter?
Hello @walton_edward.
The 10’ power cord you referenced will work fine.
I Googled your question about using it in Canada. It should work fine.
Many thanks for your help
