Wyze Cam v3 live-stream unstable after latest firmware update
I recently updated my Android app to v3.11.6, and updated all 15 (9 in one location, and 6 in a separate location) of my Wyze Cam v3’s to 4.36.16.6114. All cameras were working perfectly fine in individual live-stream view, and group view (3 cameras max per group) prior to the firmware/app update.
However, now I’m constantly getting error code -3005, and when the live-streams do load (in both individual and group view), it is not consistent and will freeze and/or error again. To clarify, all other wifi devices are working as normal with no connectivity/bandwidth issues.
Is anyone else experiencing this issue or have any ideas on how to resolve? This is quite frustrating as I now regret updating.
Same problem, I’ve power cycled my router many times, reset my cameras, removed them and added them back, and Uninstaller and reinstalled the app. Nothing has worked for long, the camera will connect once and then it throws a code 3005.
iOS v3.11.6 -
Same issue; Streams either get caught in a 1-2-3 of 3 loop, or if they load the feed shows “Live” but is stuck on one frame most times. If it streams, It is very erratic and practically useless.
Reset Service, Restart Camera, and Deleted/Re-added did not resolve the issue.
Update, I swapped out the wall plug with a cellphone wall plug and it’s been working fine since!
