Wyze Cam V3 continuous recording stop recording
@bguz1968, this was your 4th post in two different topics regarding the same issue. In each, you received replies with suggestions and information on how to fix it. If you are having trouble setting up the CamPlus Lite for your cam, it would be helpful to reply back with which cam you have, the firmware edition, your operating system, the app version, and a detailed description of where the problem lies and the function you are trying to achieve. I replied to your earlier post in this thread but did not get a reply from you.
My v3 sd card recording stopped recently. How do I fix this or get my camera replaced?
What type of card are you using? Have you tried a different card in the camera to see if that works? Have you tried the problem card in a different camera to see if it works? When you mix and match devices with cards like that you can see where the problem follows if it stays at the camera, or if it follows that certain card. SD cards do have a lifespan on them and as a rule of thumb and best practice it is recommended to use high endurance cards that can handle the many rewrites and overrites that these cards endure during continuous recording.
Let me be a Devils advocate. I buy nice stuff so I buy the most expensive cards. I mix the cards and use these in my car cams and my gopro for year’s without issues. I am also in IT so I understand flash memory and limited rewrites.
Now answer my question. WHY did all my v3s put into service at different times with different sd card manufacturers do down at the SAME TIME after firmware update? Do you think that is unlikely or likely?
I did find that i only can use new card. Onces i moved to other cam even if was cleared it would stop recording at point it full or close and need to write over its self. As i am useing 132 g cards the cam cant format the card. So onces i tryed with over size card. That card now garbage. I bought new card put in. And its been fine ever since Neaver missed a beat again. No recommend to use 132g but give me 9 day plus with no sound on to look back on. Only down size is u cant format card over size card. The 32 g like recommended work fine with format but i will not try to swap or move cards agian. I have had great winter with these cams. Hope this helps.
