Wyze Cam V3 can support lamp socket or spotlight, but not both!
Just so others don’t make the same mistake I did, the V3 can support only one accessory at a time. I have an application where I wanted to use both the lamp socket to power the camera and spotlight to light a path around the corner from the socket under certain conditions, but discovered it can’t be done.
Hopefully Wyze will get rid of this limitation in a future firmware upgrade.
If you’d like to influence Wyze’s decision to support this, post a reply/use case in the following Wishlist item and/or click the Vote button in the upper left corner of the Wishlist item.
Hoping that they fix this with a software/firmware update
