Wyze Cam v3 camplus subscription
Hi,
I recently buy a wyzecam v3 with Cam plus kit. The problem is : i cant find the way to activate my camplus subscription. Do I missed a code or something ?
Thanks all
@alexandre.trepanier1 Welcome!
Steps to activate cam plus. Open Wyze app, Account > Services > Cam Plus > Edit > Available Devices
Under Services you should see Cam Plus. Tap on it, the available paid license should appear under Cam Plus.
  • Tick the box for the desired cam, tap activate.
  • To deactivate a cam, uncheck the box for the desired cam, tap activate
When I try and activate using these instructions I get told I have no cams, but I do, and I can see and use both through the app!
@RonHaines Welcome!
Have you tried logging out of the Wyze app and log back in?
