Wyze Cam V2 suddenly stopped connecting to Wifi
Hi,
A couple of days ago my Wyze V2 stopped connecting. I’ve deleted the device and tried to reconnect to 2 different networks in my home with no success. I also tried a factory reset with still no luck. My other camera works fine on the same network. The device will scan a QR code, but then says it can’t connect to the network. Any advice, or is this camera scrap now?
Welcome back @Mike.Motorbike That seems to be happening more lately, Here is another thread for the same problem. One camera stopped working
In the end it became a dummy camera.
Try flashing the firmware.
https://support.wyzecam.com/hc/en-us/search/click?data=BAh7CjoHaWRsKwg3k4zTUwA6CXR5cGVJIgxhcnRpY2xlBjoGRVQ6CHVybEkiXmh0dHBzOi8vc3VwcG9ydC53eXplY2FtLmNvbS9oYy9lbi11cy9hcnRpY2xlcy8zNjAwMzE0OTA4NzEtSG93LXRvLWZsYXNoLWZpcm13YXJlLW1hbnVhbGx5BjsHVDoOc2VhcmNoX2lkSSIpOTFkNzY4M2QtYjc2Yi00OTE3LTkzODctZmJhODkzZGM5NTJhBjsHRjoJcmFua2kG--b65c424321fc8ac9b06361a09135b65394ab32cd
If that doesn’t help then it might be.
If it’s still under warranty I’d contact Wyze and get a replacement.
If/when you get the new firmware loaded and IF it still doesn’t work:
  • Make sure the camera isn’t connecting to your 5Ghz network (assuming) instead of the intended 2.5GHz. Hopefully they don’t have the same SSID.
  • Remove the SD card from camera.
  • Turn off mobile data on your phone.
  • You could also try connecting on an unrestricted network (like Starbucks).
