Wyze Cam v2 fails to connect, keeps timing out
I have a new wyze cam v2 which i cannot get to connect to my home network. I already have three wyze cam v2;s all working fine.
When i try to setup the camera I follow the normal steps to connect the new camera using the wyze cam app. After canning the QR code it keeos timing out.
  1. I have tried a different micro sd
  2. Ensured the the home wifi is only running 2.4Ghz
  3. Tried using different micro usb cable
  4. Different usb power plugs
  5. Reset wyze cam by holding the button down for 20 seconds
  6. Ensured no ports blocking etc… iin thr router.
I extracted the logs from the router
DHCP device Disconnected: 192.168.1.155, a8:3f:a1:85:69:6b, unknown
17:39:39, 08 Apr.
LAN [DEL] ARP 192.168.1.155 with a8:3f:a1:85:69:6b from br0
17:39:39, 08 Apr.
2.4G Client disassociate from a8:3f:a1:85:69:6b (IP=192.168.1.155) RSSI=0, Rate=0Mbps
17:39:38, 08 Apr.
WHW INFO A station STA(A8:3F:A1:85:69:6B) leave WHW infrastructure
17:39:38, 08 Apr.
2.4G client Mac: A8:3F:A1:85:69:6B Deauthentications (Reason:Deauthenticated because sending station is leaving (or has left) IBSS or ESS)
17:39:30, 08 Apr.
ARP [add] br0(wl1) 192.168.1.155 a8:3f:a1:85:69:6b
17:39:25, 08 Apr.
DHCP device Connected: 192.168.1.155, a8:3f:a1:85:69:6b, unknown
17:39:25, 08 Apr.
2.4G Client associate from a8:3f:a1:85:69:6b (IP=192.168.1.155) RSSI=-44, Rate=65Mbps, host
17:39:25, 08 Apr.
LAN [ADD] ARP 192.168.1.155 with a8:3f:a1:85:69:6b from br0(wl1)
17:39:24, 08 Apr.
Receive a DHCP request
17:39:24, 08 Apr.
WHW INFO A station (SmartHub2)IF2.4G:STA(A8:3F:A1:85:69:6B)(Legacy Device) join WHW infrastructure
Appreciate if someone can help to advise.
Have you tried moving the camera closer to the router or one of the working cameras? Can you try a different wifi?
