I have the WYZEC2BK model that stayed plugged in to an outlet and worked consistently, but now no longer works, and makes a chirp noise periodically. The power cord is not the issue as this and the USB plug have been swapped. Also plugged the device into a different outlet. Nothing works. Although I have performed over-the-air (OTA) updates before, the camera has not worked since the last update. Although, the camera is out of warranty, given this recent OTA update, is there a way Wyze can repair this unit? It is not a solution to just “buy another one” if this one that was working fine, just stopped suddenly.
Welcome to the forum @raca414
You can attempt to Flash the Wyze Cam V2. Directions on how are located here:
Scroll down to
Flash Firmware for Wyze Cam v2 & Wyze Cam Pan
For your specific camera.
One of my black V2 cams seems to also be having a problem with the latest firmware. I have been able to successfully set it up again a couple of times, but I can’t get it to show as online or stream or anything and the status light goes back to flashing blue and yellow. Since I had not heard of anyone else having the problem yet, I have not done much about it or said anything, as I assumed it was an isolated incident.
If you try flashing the firmware before I do, let me know if it helps.
The firmware flash was ineffective.
- Prepared the SD card as instructed.
- Renamed the bin file to “demo.bin”,
- Powered off your camera and inserted the microSD card.
- Held the setup button, plugged in the USB cable,
- Kept holding the setup button for 3-6 seconds, but light did not become solid blue
