I lost remote live streaming on all 5 cams after update, so I reverted back to previous version and got remote live stream back. Thank you for making the cams with the ability to flash backwards.
@Canral. You have the half volume issue with the v2s? I thought it was a wyzecam pan related issue seen here…I didn’t have an issue with a v2 that I updated.
Sounds good
hi, i have one v2 cam on .108 and another v2 on the prior firmware. I can only hear the sound on the v2 still on the prior firmware,
To Whom it may Concern,
Was able to get Wyze Cam, and Pan working. Problem occurred following
4.10.3.108 upgrade. Cam, Pan no longer Wi-Fi connected. Pan when
rebooted rotates to one extreme range to other range, then gets stuck
at second extreme, camera pointed upward.
Tried to no affect:
- Reinstall three (3) recommended upgrades for Cam, Pan,
- Reboot Cam, Pan with flank flash drive, followed with three (3) upgrades.
Cam pan caught my landlord (Imitation Engineer, NOT licensed
Professional Engineer,) entering me room while in WI assisting my
sister.
That said, would REALLY like to get at least ONE camera working.
Thank you,
Welcome to the community, @sefiedlerpe. I have moved your topic here where issues with the firmware are being discussed. Please see if anything in this thread is helpful to you. ![]()
Keep in mind that this forum is primarily a user to user community. If you don’t get a helpful reply here, please file a Support Request. Depending on the nature of the problem, rather than use the website link, it is helpful to submit an App Log and/or a Firmware Log.
