Wyze Cam Pan V3 and mistaken identity(grill)
My Wyze Cam Pan V3 thinks our Kamado Joe ceramic grill with grill cover is a person. I submitted feedback in each event by unchecking “Person” and selected “Nothing”. I did this feedback several times over several weeks but Cam Pan V3 still thinks our grill is a person. Any suggestions on fixing this mistaken identity?
Gene
I am having the same issue. It keeps identifying a plant as a person and I get critical alerts one after the other even after turning off all the notification settings. This is on their duel cam doorbell. AI has a long ways to go and it is irritating me enough to buy a whole house DVR system again.
@thewelvaerts and @bmwz3_diane confirm that you don’t have “other motion” enabled. When you have “smart detections” enabled it sometimes hides this setting, you may need to change it from “smart” to “all” then go into the “customize” and uncheck the ones you don’t want (like other motion) in there.
That may or may not be your issue, but it has been a problem for others. Granted if yours are being tagged as “person” it may just be the algorithm not being perfect (which it isn’t) in which case greying the grill out of the “detection zone” should take care of it.
Thanks Dave. I made the changes as suggested and will let you know if the issue continues.
After making the recommended changes 3 days ago the issue is resolved.
Thanks!
I did that to my cams and STOPPED all the alerts
Stopped the unwanted alerts or all alerts? If you have a cam plus subscription you should still get the “smart” alerts as long as the cams have a good wifi signal and your internet upload can keep up with it.
If you don’t have a subscription, yes unchecking that will stop all alerts.
Oh yes. I have the same issues with my Cam Pan v. 3, with the most recent firmware 4.50.5.1318. The AI does not have any intelligence, just Artificial. Wyze needs to pull the AI feature until it is revised, adequately tested, and actually works. My camera, especially at night, says it is detecting a person, shows the red tracking box, and migrates to view the wall behind it. There is no person, animal, bug, just nothing. It is extremely frustrating. I have been recommending Wyze, but now not so much.
Wish I had a solution. Hey, Wyze, how about some guidance on this.
