I will be swapping a V1 Cam Pan out with a Pan Cam V2 that has been mounted outside for over 2 years and will provide some side by side comparisons once I have collected some data.
Indeed, nor was the V1 but I’ve had one outside for awhile and it’s performed well in all mid-west weather. Should the V2 not do as well… then the V1 can come out of retirement.
I suppose with that I should also mention that I take full responsibility of deploying a non-outdoor rated device outdoors, My experience is not one of a recommendation to do so, but more of a discussion of my experience using it outside of Wyze’s recommendations. I do so mostly because I like that the device can track motion vs deploying multiple devices covering intersect points.
And for those interested here is the state of the V1 that was mounted outdoors for 2 years and some change. There was no discoloration or weathering anywhere the silicon case covered.
The bottom was a little off white and the sd card was in perfect condition.
Same for me. What I have seen in the past is it takes Amazon a bit to add the nee devices to their live view, and without notice you will just happen to see it one day. As was the case with the V3. Still waiting on the video doorbell, and my guess is the WCO will never make it on the list at this point.
