Version: 4.49.1.25
WHAT’S NEW:
- Fixed an issue that caused the device to reboot
Version: 4.49.1.25
WHAT’S NEW:
Installed without issues. Will monitor to see if there are issues.
I will definitely be installing this when it shows up for me. Cameras exhibiting this issue
I went to Firmware update and it was there. But I did have to select Cam Pan v2 in tbe Beta FW list under about / Beta Program
Good call!!
I forgot to do that and firmware showed up right away.
Installed without any issues
Updated and working fine so far.
Installed update and hasn’t rebooted in over an hour, previously every ~23 minutes. Thanks!
Lines across feed - live-stream, event recordings and playback with this firmware version.
We used to have the Pan, sitting in the same spot as the Pan 2 is currently. We had no issues with Pan, but we have issues with Pan 2 using the 10/4 firmware.
I was wondering if there is RSTP firmware for the cam pan V2 yet? Or any planned development for it
@WHYSNOT
There is none for the Cam Pan v2 yet. I do believe they are planning on it although I cannot point you to any official word. It takes awhile before the RTSP will show up, they first try to get the production firmware to a relatively good point then they will work on the RTSP version. If I am not mistaken it took just under a year for the v3 to receive RTSP
