Wyze Cam Outdoor v2 & Battery Cam Pro Firmware Beta Test 7/2/2025
Wyze Cam Outdoor v2:
Version: 4.48.4.450
What’s New:
  • Fixed an issue that prevented scheduled recordings from being deleted in the app.
Wyze Battery Cam Pro:
Version: 1.4.4.4717
What’s New:
  • Added support for Bird Detection
Just updated my 3 BCP’s to beta b4717.
Samsung S24 ultra and Samsung A9+, both on android 15.
Updates installed without issue but I noticed something to be aware of. I do not allow any app or phone updates to do so automatically. I want the final decision. Been working as expected.
After updating I was looking at the screen and the update has defaulted to automatic on. I was able to change it without issue but if I hadn’t noticed it the next releases would install automatically. Not sure if this beta caused this but beware.
As for Bird Detection. It has been schizophrenic. Some days I get notifications, some days I don’t. In fact I was disabling descriptive events when this update occurred. Let’s see what this beta brings to the table. I’ve been burned a few times thinking it was fixed so I’ll probably watch it for 3-4 days to see if it’s stabilized.
Thank you for the reminder, I just Disabled Automatic Updates on my four BCPros.
Not sure if this is the best place to make this request, but is there any way of setting a global “Disable Automatic Updates for all Devices” in my Wyze App? When one has 20+ camera’s, checking/setting this once at a time is tedious.
I just as soon have an app setting that let me Disable once for all devices, and leave it that way, even after firmware updates.
I’m not aware of such a setting. It has not been an issue in the past as the setting sticks. Not sure if this is a bug in this beta.
BTW. Before the update I did not have a single bird event in the past 24 hours. Since the update, just a few hours, I’m getting an event about every 15 minutes. This coincides with what I’ve seen on the SD card. Let’s hope it continues.
Good luck on your 4 units.
Now we need automations to have Birds for a trigger so I can have certain Wyze Color Bulbs turn on for such events.
Are you creating a bird disco :mirror_ball: ? :grin:
CatHome, now I get it, when the light goes on, your cat knows when to strike! :joy:
Disco indeed, I like that description, off to eBay to hunt down a disco ball…
I have a Ceiling Fan setup to flash or turn one or more Wyze Color Light Bulbs based on various triggers on various Wyze Cams strategically placed around my property. Red :red_circle: for Persons :people_holding_hands:, Green :green_circle: for Pets :dog: :raccoon: :cat: :rat:, Yellow :yellow_circle: for Motion :man_running:, and perhaps Purple :purple_circle: for Birds :dove: :eagle:, if and when that trigger becomes available in the Automations :slight_smile:
I posted on wish list the ability to have those notifications trigger to open the app and show the camera video. I’m not sure how much it would take to create such code. But how helpful that would be!
Even better, to open the recording of the event that triggered the Notification in the first place.
