I don’t quite understand the SD card recording. Both of Wyze Cam Outddor v1 & v2 have SD cards in them. My Base Station has an SD card. All of my setting are set to record on SD card and back up on base station SD card. Yet, nothing is recording. Thoughts?
Do you have Cam Plus or any paid cloud service for event videos. Back up to the Base is not compatible with paid cloud service, no backup to the base.
Recording to the SD card in the cameras can only be done using Scheduled Event Recording, I will post direction below. I have used mine for Scheduled event recording, set for 30 days, 23 hours, MOTION ONLY, No cooldown period, and a maximum duration for each video at 5 minutes. The camera will record to the SD anytime there is motion. To view what was recorded you have to open the app tap more on the bottom right then tap album. Then go down to scheduled recordings and you will see what was recorded and it will look like this:
It used to show a picture of the recording but they hosed that up also with one of the updates?
To view what was recorded you have to tap the download arrow on the small picture to open it to paly and it will also be saved in your phone media gallery. You can also take the card out and view it on a PC or device with a card reader. You can find out how to set up scheduled recording on this link.
Confused yet?
