Wyze Cam Outdoor firmware - Released 1/4/2023
Hello, friends! We are releasing Wyze Cam Outdoor v1 firmware version 4.17.4.418 and Wyze Cam Outdoor v2 version 4.48.4.418 to fix a bug that prevented the rotate image 180 degrees setting from sticking. :upside_down_face:
Read our Release Notes:
Why can’t this camera record on the SD Card?
It kind of can if you really need it to.
People do the “Schedule a recording” option, and then tell it to record events-only. Then it will record all motion events to the SD card.
Then, when an event happens, you check the time it occurred and then go to your album and download the event for that time period to watch it.
You have to reset that scheduled recording option once a month though.
Additionally, it can do continuous recording as a scheduled recording, but it will kill the battery pretty fast, and it won’t loop.
It will also record timelapses to the SD card.
So there are ways to record to the SD card if that is really important.
