Wyze Cam Outdoor Camera Limit Workaround?
Assuming the Wyze Camera Outdoor hub is still limited to 4 cameras, can one simply add a 2nd hub and access it from the same account, or is one required to start a different account for the 2nd hub?
You can as many hubs in your account as you need. But each hub can only have 4 cameras per.
This is mine, and not even them all. Only one is in use right now.
