Connect up to cameras to a single base station and view all video streams in the Wyze app
Hi there! I have a question, it says that you canConnect up to 4 cameras to a single base station and view all video streams in the Wyze app, does it works only with outdoor cameras? or it works too with wyze cam 2 or v3. Thanks!
The Base station is only for the out door camera’s. The V2 and V3 are WiFi camera’s.
The Wyze app allows you to group cameras and view them. Works with outdoor, wv1, pan, wv2, wv3.
The base station can have 4 outdoor cameras. No base station is needed for the other cameras. Only the outdoor camera requires a base station.
I want to add, you can mix/match camera types in groups. For example, I have 2 outdoor cams and a V3 in one group, and I have a V2 and 2 pan cams in another.
Can I add a fifth wco to my base if my usage is low with the existing four?
Currently 4 is the max. Good idea, but it doesn’t matter the usage level of the individual cameras, it’s capped at 4 connections per base.
