I have the Wyze out door cam V1 and was wondering if I could use the add on camera from the Wyze outdoor cam V2 add on camera? Would they be compatible? The camera I need has been out of stock for awhile now.
Yes. The v1 and v2 use the same base station. You can connect a mix of up to 4 Cam Outdoor v1 and v2 cams to one base station.
Thanks so much for the info. You helped a lot!
No problem!
