Mix and match Wyze outdoor cams
Does anyone know if you can mix and match v1 and v2 outdoor cams on the same base station?
I’d like to try out one or two of the newer outdoor cams at first to see if it’s worth dropping another $200+ on upgrading.
@Memoir-Of-A-VCR
You can use both v1 and v2 WCO on the same base station.
Only 4 Cams per base so if you own one or two Version 1 WCO you can only add two version 2 WCO to the same base.
If you want more you need to purchase another base /camera combo. I don’t think base stations are sold as a single item.
