Wyze Cam Floodlight Pro
The Wyze Cam Floodlight Pro connected to my original outdoor cam hub. Was it supposed to? I thought the Wyze Cam Floodlight Pro connected to the router on its own. Now the 2 that I installed this week are using 2 of my 4 available camera slots on my hub. My original hub is connected to my cable network. Sorry if it’s a dumb question.
How is it that you are determining that the FLP is connected by WiFi to your Wyze Cam Outdoor Base Station?
When you installed the FLP, did you select your Home Network WiFi SSID Name and enter the Password?
Can you show screen shots of your base station device screen showing the connections? And/or the device info screen from the floodlight pro showing this?
Yes, I selected my Home Network WiFI SSID name and entered the password.
Then it should most definitely be connected to your WiFi Router 5GHz or 2.4GHz band. What is your WiFi Router telling you?
Finally figured it out. Thanks.
