WYZE Cam custom notification sound
New to the WYZE cams. I’m using Android 10 (Pixel 3) and I was wondering if I can set a WYZE specific custom notification sound?
Hello @Codaman and welcome to the community.
Currently you can not do this without doing a workaround. I linked the workaround you can use to do this below. I also linked a Wishlist topic where you can vote for this if you would like. Just click in the upper left to vote.
Thanks. I’ll take a look
Yes, it can be done with Android. Details on the photos:
That will change the sound for all WYZE notifications but the sounds for each notification coming from WYZE will still all be the same. The work around I posted will make it so you could set each camera or sensor with a separate sound
