Can you give each camera a different notification sound? I can apply a sound through App Notification sounds but that then applies to both my cams. I need a different sound for each.
Funny you should ask. Member @jezmck just posted a blog on how to do this:
Note that this only applies to certain versions of Android. If you are using older Android versions or iOS, you are out of luck for now. If that’s the case, you’ll want to hop over to the post below and vote for it. (You just click the VOTE button at the top of the page for your vote to count.):
